myredracer
Apr 22, 2018Explorer II
DiskDoctr wrote:
I believe you have that backwards....
XPS (blue/green/pink at big box stores) is considered non-absorbing and EPS (white) is water absorbing.
Owens Corning XPS vs EPS water absorbing foam
I believe you might be correct... (Memory isn't what it used to be.)
Every time I think about the foam they use in the walls, I just can't believe they use something that absorbs moisture. Not good when cold weather camping.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 06, 2026
