Dakota98
Mar 23, 2015Explorer
Dutch_12078 wrote:
An easy way to cover the old hole is to use a blank plastic electrical cover plate held with a couple of small wood screws. If the hole is too large for a single plate use a double. They come in standard outlet colors.
Another method I have used is purchase a piece of project board from Lowe's or HD. As the OP stated, he would like to move the thermostat higher up on the wall, but there is some sort of monitor panel in that area.
By using a 1/4" x 6" or 8" project board, rounding the corners or trimming it, giving it a finished look, the monitor could be moved up higher along with the thermostat, covering the old holes & making new ones for the monitor & new thermostat.
just a thought.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,418 PostsLatest Activity: Sep 12, 2026
