Chris_Bryant
Aug 31, 2015Explorer II
Chandler1 wrote:
During my troubleshooting I removed the nuetral wire connection for the new air conditioning line that goes from the 20A circuit breaker into the old RV circuit breakers. The wiring to the actual air conditioning unit still has the nuetral connected to the bus and also the main line output from the inverter still has nuetral connected in the old rv circuit breaker.
I'm having trouble with this part- you shouldn't be able to remove connections and still have it work- though I'm not sure why or if that would cause the problem with the gfi. Keep in mind the Xantrex *may* bond neutral and ground while running.
I would question why you didn't either set the "trip" points looser on the Xantrex, or even just turn it off while running the air.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
