Commerce's avatar
Commerce
Xantrex Inverter/Charger
I have a 2004 Tiffin Phaeton and recently noticed my four 6 volt house batteries were always reading low even after hooked to shore power or generator but after a long drive they were back in the green. I finally had a tech look at it and he tells me the charger is only putting out 12.8 volts where it should be putting out between 13.6 and 14.2 and that I need to replace the Xantrex 458 charger converter.
I am assuming he is right abotu this but just wanted to discuss it with this board to see what your suggestions are and also should I go back with Xantrex or is there a better option ? The good thing about if I go back with the same Xantrex unit is I will be able to use the same control box up front from the old unit I assume.
