Chandler1
Aug 31, 2015Explorer
I set the trip points on the Xantrex as loose as possible in the on screen controller. The lowest incoming allowed is 78Volts. The Xantrex is also tripped when I shut off the air conditioning and the high allowed voltage is set to 140V. Shutting off the Xantrex doesn't help any if the main AC for the coach passes through it. I can disable the inverter while passing the AC but still have the control problem shutting off the AC when air conditioning starts.
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,402 PostsLatest Activity: Mar 23, 2026
