S_Sullivan's avatar
S_Sullivan
?? RE: Slide switch ....
We recently purchased a 2002 Cardinal WBLX. When looking at the rig the first time, the owner opened both slides and we were satisfied that all was functional. After the deal was made, but prior to picking up the unit (we were going to have it inspected), we went back to look it over again. At that time, we realized that only one switch operates both slides. The bedroom slide goes out first and then the living area slide. Regardless of the position of the slides, it ALWAYS opens the BR slide completely before it will move the LR slide.
Example: You are bringing in the slides (BR is already in and closed tight), the LR slide starts in and you realize you didn't move the throw rug. You need to move the LR slide back out about 1 inch or so in order to pick up the rug - you can't do it until the BR slide is completed out. Having one switch to operate both slide is just a dumb idea to me.
My question is this: Has anyone else ever had this situation and had the switch rewired so that there are two switches? Is it even possible? And if it is possible, is it financially feasible?
Thanks in advance for your help.
