Socom wrote:
Just bought this 04 cougar travel trailer. Slide out is only working on battery. I disconnected the battery, plugged up to service and slide doesn't work. Is this supposed to be like this or not.Any suggestions on where to start looking for the issue would be helpful.
Many, if not most, slides run directly from the battery. You =have= to have the battery connected for the slide(s) to work. 12v from the converter runs through the battery to the slide motor(s). If you have a dodgy battery, the converter may not supply enough juice to both charge (or attempt to charge) the battery =and= run the slide motor at the same time. Charge the battery for 24 hours, then have it load tested. If it fails, replace it.
Lyle
