Sam Spade wrote:
Cummins12V98 wrote:
IMHO still not a good idea as the HOT temps vary wildly.
If you are heated up and below "MAX" pressure you have a tire problem.
Well that first sentence depends on your definition of "wildly" I guess. Under similar conditions, the pressure should be similar.
And I don't think I agree with that second sentence at all.....but not sure what you are trying to say.
Conditions vary as a person could be traveling in freezing or 100 weather the tire themps will vary "A LOT".
If traveling on a 100 degree day and your tire reads 80 psi and that is it's max the tire could easily have only 40psi cold and may have a hole or ?????
Really, who checks their tires HOT??????
