Its recommended that tires on trailer be used at max sidewall pressure ...however if that 3000 lbs per tire is a actual scaled number then I would do as these experts say.
rvsafety.com
Tire Load and Inflation Ratings
* Note: Towable – Travel Trailer/ 5th Wheel owners Due to the severe use conditions experienced by tires when axles are very close together – tire industry experts recommend maximum (sidewall) inflation pressure for towable tires unless this causes a sever over-inflation situation (20psi+), often referred to as the ‘basketball effect’. If this is your situation allow a 10 – 15psi safety margin above the minimum required inflation pressure.*
And some good pointers on trailer tire pressures from another source;
fifthwheelstreet.com
Step #5..
Selecting the Correct Tire Pressure for Your Trailer
We at Fifth Wheel St. no longer recommend adjusting trailer tire inflation pressure below the maximum load PSI rating molded on the sidewall (and only if the wheel/rim is appropriately rated) regardless of the measured scaled weight of individual tire or axle positions for all multi-axle trailers.
However, we do strongly recommend weighing individual trailer tire positions to ensure none of the axles or tire positions are overloaded. Reports have shown that trailers do not have equal weight across all tire positions. Some RV load configurations may reveal as much as 20% difference between the front and rear axle. This especially true for Toy Haulers. It is possible that mismanaged trailer load distribution will cause one end of an axle or a tire to be overloaded. It has been stated, but never confirmed by any RV Weighmaster, that there are many RVs traveling on the road with at least one tire or axle side overloaded. The only way to ensure tires and or axles are not overloaded is to weigh each tire position on your trailer. Unfortunately, attempting to obtain accurate individual tire position weight is practically impossible at all truck scales. View our list of recommend RV Weighmasters here.
- See more at: http://fifthwheelst.com/step5.html#sthash.FIAc3k0Z.dpuf
I don't carry a compressor ....can't help you there.
