I would run 5 to 10 psi above the chart not to exceed sidewall max.
Running max is fine too. Check pressure before you roll and before the sun is on the tires.
A quality 12v compressor will go 110 - 150 psi. If it has a cigar plug it is weak. If it has a 30+ amp fuse and clamps direct on the battery you should be fine. My MV-50 works fine for me but it might take a bit to get to 110 psi. Viair is also a great brand.
Or for the big boys there is Oasis that draws up to 200 amps and makes 200 psi.
http://www.oasismfg.com/dc-air-compressors.html
