ken burke wrote:
All . . . . help. What tire pressure should I use on my ST235/85R16 tires by West Lake (forest river). My 5th wheel is heavy, i.e. 3000 pounds on each wheel and tongue. (15,000 pounds total). My tires are G rated and limit is 4080 pounds (actual weight is 3000). Max presser on is 110 psi. Do I have to run that high of pressure??
The problem is how to I get that pressure with a portable tire inflator? Also most tire inflators are DC hooked up with the trucks 12 volt. that won't work.
thanks . . . . ken
How long have you had your 5th wheel?
