Searching_Ut wrote:
I too have G rated tires on a similar weight 5er, and have found 110 PSI seems about right, even towing on snow and ice. After about 7000 road miles now tire wear looks even and minimal. I use a Viair 450p DC inflator that I clamp right to the 5er battery most of the time as it's easy to get at in my rig. The little DC compressor works as good or better than the craftsman 4hp 125 psi compressor I have in the garage which doesn't go high enough pressure wise to fill the trailer tires most of the time due to the way it cycles.
All . . . thank you all for your quick and complete response to my question. I just ordered the Viair 400P-RV thru Amazon. Cost was $251. As above it is a DC pump that connects to the battery. This should solve my problem with G rated tires. thanks
