MM49 wrote:
Me Again wrote:
Max sidewall inflation seems to be a band aid that the ST tire people came up with in an attempt to increase the life cycle of their product, with mixed results and far as I can tell.
I have talked to Michelin several times and they state over inflation leads to impact damage to the tire and decrease contact/braking performance.
Chris
Wow, is there no limit to your dishonesty?
MM49
That is a true statement, where is the dishonesty. Had a neighbor that was a log truck owner, ran his tires at 90 psi (110 psi tires) to limit cuts and carcass damage from the large rocks used in logging roads.
