jadatis wrote:
I am planning to make pressure loadcapacity lists for ST tires .
In that for every pressure in steps of 5 and also 10 or 20 psi over "maximum pressure", a colom of 5 loadcapacity's. At top for 65m/h at bottom lowest load that still gives acceptable grip and comfort.
Are we talking about ST tires here or LT tires.
St tires are calculated in their maximum load for lower speed so more deflection.
If they are LT tires they are calculated in maximum load for 99m/h so lesser deflection.
So my opinion is that for LT tires follow my pressure/loadcapacity lists and add up to 18% to the weighed wheel load first before looking back the load in the list.
but if you have ST tires first calculate the maximum load back to 99m/h .
For this see my topic here
how to compare tires for replacement
And for the extra save pressure loadcapacity lists see next map on my one.drive
Extra save pressure loadcapacity lists
Using this topic and P/LC lists you can determine a highest pressure at wich comfort and gripp is still acceptable and gives as much possible reserve for things like , pressure loss in time, misreadings of pressure scale, mis-yudging of loads on tire, etc.
fmnjmnjoeawhtnaoerltuwe40thng'dsto9user
