BeardownAZ wrote:
Hello. Looking to get a toy hauler, used, that I can tow with my 2014 f-150 ecoboost. Will need hauling a polaris Rzr 4 900. In the $5000-7000 range. Seen a few Carsons fun runners and Thors in that range. Any thoughts suggestions? Needs to sleep 2 adults 3 kids. Doesn't have to have fuel station or generator though I prefer on board generator. Thanks
Yes the new trucks are impressive and capable. But why use a 3/8" ratchet to take off your lug nuts, yes it will work most of the time. But chance of breaking the ratchet mechanism are high. And the effort needed to do the job, also high.
The right tool for the job makes everything safer and easier less stressful, with less chance for damage.
Like most here have tried to explain, what you want to do, is probably going to have you towing over weight, by a considerable amount.
Tow capacity is not your problem towing TH's. Its achieving/loading the correct tongue weight, and being able to haul that TW within your trucks hitch/payload weight ratings.
A real TH that fits a RZR4 comfortably, correctly loaded, will have a TW over your Fords 1100lb receiver max capacity, before you even start to subtract payload inside the truck/truck bed. And your rear tire/axle weight will be over or maxed out also.
You're going to find the real world weight of your rzr4 900 wet', with fuel, battery, oil, coolant, doors,roof, lights, seats, etc, is closer to 2000lbs then your 1500lb(manufacturer dry) estimate. Might also need a 12' garage at least 72" tall at the door/ramp entrance as to not damage anything. Thats not a light weight TH as far as I've seen. Maybe some new TH model is available that will do what you want..? But you're looking for a used older TH, correct..?
Look on your Ford hitch and check the weight rating.
Weigh the TH tongue. Do not go by the manufactures 'dry' TW sales brochures. Load your TH tw so as to be around 15% of the scaled TH weight for sway free towing.
Figure it out for yourself and decide if you want to tow over weight swaying with the slightest provocation,or not. Many do just that. Your call...
jmo
