laknox
Dec 13, 2017Nomad
fullydeuce wrote:
I am hooked up to shore power, that is why I was thinking it was the converter. I know the battery isn't holding much of a charge either. What is the best way to troubleshoot each one?
First off, pull the battery and put it on a charger for several hours, then take it in and have it load-tested. If it's toast, then replace it. Next, check to see what voltages the converter is putting out. If it's not up to proper voltage to charge the battery (14+), then it may also be going out. If you have to replace that, then put in a =good= one, with multi-stage charging. Your batteries will thank you.
Lyle
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
