kerrlakeRoo
Dec 13, 2017Explorer
Going off altogether, and then coming back on can be just bad connections to the batteries. After you have verified you have a good battery and ensured you have good clean connections to the batteries check the voltages.
Converter off, voltage at the battery should be about 12.6.
Converter on, it should be 13.6 to 14.8
then determine if you want a new converter.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
