time2roll
Dec 13, 2017Nomad
fullydeuce wrote:Disconnect a battery cable to separate. Converter should hold 13.6 volts DC in the fuse panel running everything.
I am hooked up to shore power, that is why I was thinking it was the converter. I know the battery isn't holding much of a charge either. What is the best way to troubleshoot each one?
If the battery is below 12.6 volts... charge it and then see if it holds 12.65+ volts for 2 to 7 days disconnected.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
