Cummins12V98
Apr 08, 2016Explorer III
You said "The pin box is in its lowest position" Did you mean highest???
If it's in the lowest that means it can be raised to accommodate a higher hitch.
MeAgain uses a Demco picture frame adapter and B&W slider that works well with his SRW RAM.
To do the above you need the pucks. They are easy to install if you don't have them.
About Fifth Wheel Group
