rhagfo
May 28, 2016Explorer III
M.R.E. wrote:
What 5th wheels are you towing ? My Columbus 340rk states 1800 lb pin weight , which shouldn't be a problem .
The rest of the story;
2014 Palomino Columbus 340RK Specifications
Technical Specifications:
Length 36'-6"
Dry Weight 10,905#
Payload Capacity 3,075#
GVWR (lbs/kgs) 13,980#
Hitch Weight 1,980#
You didn't state the year this is the closest I could find.
The 1,800# pin is lite for the weight of the rig about 18 percent. That should increase to at least 2,500# (20 percent of 12,500#) this assumes you only load to 12,500#.
Still doable for a 2500, if you decide to run over GVWR. That is your decision.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
