We have just purchased a new rig with 2 air conditioners. Camping next weekend with weather forecast to be hot! If everything else is on propane can we run one air conditioner?
Turn off everything including converter and if line voltage is not low, maybe. Even with normal line voltage in this heat the A/C will draw almost 15 amps. Might want to get a couple of fans instead. Good luck.
