DatonPlace wrote:
I own a 2014 Ram 1500 Crew Cab with the RamBox 5'7" bed. I have factory installed towing, and the 5.7 Liter Hemi engine. I want to get a Fifth wheel toy hauler to tow two Harley Streetglides weighing approx 1600lbs combined. The GVWR is 10300lbs, Max Payload is 1625lbs...Do they even make a Fifth wheel toy hauler that would work? I cannot seem to find anything. I was told that I could get the AirLift product that would increase my GVWR by 1000lbs, but still I am having trouble finding a fifth wheel that meets those requirements. Any suggestions?
Thanks in advance.
Daton
I see you are a new member, so I will do what others have not (yet!) and that is to welcome you to the Forum.
Having said that, there is no way you are going to find a fifth wheel toyhauler for two Harleys that will not severely overload your truck.
You MAY do better by looking for a bumper pull, but your choice is going to be very limited.
You really needed to do a lot of homework before you bought the truck I'm afraid.
There is nothing you can do that will change the factory specs.
Airlift will help reduce the rear end sag - it does NOT change the numbers.
