larry_barnhart
Dec 29, 2013Explorer
Cummins12V98 wrote:
As long as your RV actually weighs 16K or less and the pin weight is at or below the hitch specs you will be fine. Anything that is engineered for a specific spec has a huge fudge factor.
If you want a heavier duty hitch check out the B&W they are very simple in design and top quality USA Made.
I just came back from talking to a neighbor that arrived yesterday. The B&W hitch will not disconnect from the truck. It is the first hitch of that brand I have seen and it looks very tough but something broke inside. I will find out when he gets it off and repaired. I asked if he knew of some things that can help and he knew and had tried them. Nothing is perfect.
chevman
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
