bassman2572
Jan 17, 2019Explorer
As you might have seen in my previous post about the freshwater system, I made a little modification to the frame of the sofa. The sofa does make a bed by sliding out the base. Here is a pic of the base as it would be in the seating position.
To make a bed, you just slide out the top part. It is incredibly simple construction, no "drawer" slides or any other hardware, just notched wood.
So, when I removed a piece of the plywood to access the pump, I saw all the space around the tank and decided I should be able to access it. So I attached a piano hinge to each section to be able to use for storage of seldom used items.
I can see hot dog roasting forks living here:
With the limited space in our little trailer, I felt that I have to use every little cubby hole. With the help of my mother, we made some slip covers to hide the terrible dye job the previous owner did on the cushions.
This sofa makes a bed just shy of a queen size mattress. The dinette also makes a bed. This allows this little RV to sleep 4 adults and 2 kids or maybe 2 adults and 4-6 kids. Pretty impressive in my opinion.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
