SmokeySouthpaw's avatar
Nov 27, 2025
1988 ford cobra
I just got a 1988 ford cobra motorhome. I drive home about 120 miles and I had to get gas 3 times. $60 first $88  then $70. I the fuel pump is new according to seller but the gas seems to have gone too quickly. Any suggestions as to what the cause might be or is this normal?
  • I kinda feel sorry for your complete lack of knowledge here. What you said though is virtually impossible to experience. And maybe your math or description is off.  Also presuming the fuel tank is much bigger than the 15-20 gal (why you quoted $ and not gal is also strange…) your adding every 40 miles.
    Until you can provide discernable numbers and an actual detailed explanation it is impossible for us to tell you whether it’s you or your camper that needs repair.
    But you DIDNT get 2 mpg unless it literally has like a 1050 Dominator carb on it a fuel leak.
    I think you need to do better math personally.
  • Back of the napkin, At $3.50 you got about 62 gals of fuel. At an avg of 8 mpg your range should be almost 500 miles. Now we don't know how much fuel you used on the last fill up but for the sake of argument you used it all, you're getting about 2 mpg. Definitely a problem. As far as diagnosing your problem, no one can armchair this one based on the information, or lack of.
  • You do not state the details. How big of a motor, how much the unit weighs and how many gallons of gas. Price of gas means nothing as $218 could buy you 82 gallons in South Carolina and about 38 gallons in California. Chances are you have a large engine that may even need premium gas. A rough guess is that a unit of that era would get between 6 and 10 mpg. Add age and wear to the equation and it may creep down to less than that. Come back with some details and we will try to help you.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
