- LwiddisNomad III
Too late now but I take numerous pictures as I put something together or pull anything apart.
- Grit_dogTrailblazer
Well, either the OP forgot they posted a question, figured it out or possibly sitting, staring at cooked electrical system becuase + can’t = -.
Musta forgot how to find your question you posted too…
+ wires go to + side, the rest go to - side. If you guess and don’t check you’ll know immediately!
PS, the chances of someone here having that rv are almost 0 and the chances it’s got all the same wires after 40 years is even less.
if you removed the wires from the battery and suffered short term memory loss and/or didn’t label, just check which ones are continuous to ground and the rest are +.
If you don’t understand that, call a mechanic or make sure your comprehensive policy is paid up! - StirCrazyModerator
maybe add a couple good picture of what your dealing with and even thoes that don't own that spicific rv might be able to help you
