Jeff___Claudia
Jun 04, 2014Explorer
1st 5th wheel
We just picked up our 1st 5th wheel a Jayco Eagle Premier 351 RLTS . We previously owned 2 Jayco tt's each time moving up. Shake down cruise is this coming weekend for 5 days.
travelnutz wrote:Nutz,
kaydeejay,
We see it differently but my view/posts are from actual conducted test data, engineering manuals, and written accepted Physics etc Laws.
The 12K on the 4 trailer's tires to road provides more friction on the roads surface per square inch of contact than will the 10.7K on the truck's tires would. Then add in the pulsing effect created by anti-lock brake systems on the modern truck when any wheel slides or rotates less RPM's as the others on the roads surface. The trailer's brakes do NOT pulse at all as they are electric solenoid constantly activated and apply continous braking force on all 4 wheels/tires and will apply more measured and calculated friction to the road's surface than the truck's tires will with it's higher load weight. Refer to the engineering manuals and it's very clear and what I had experienced in seeing test/certification videos. Most were done by the insurance institute but some were done on manufacturer's test facilities. I can't go into in depth detail as to which. Nor could you as a past employee.
I can simply turn the adjustment thumb wheel on my trailer brake control on the bottom of my IP to make the trailer brakes do all the stopping when my truck's brake pedal is just slightly depressed. OR Turn it the other way so the truck's brakes will do nearly all the stopping. It's a MUST to have the trailer be pulling backward on the tow vehicle in braking simply because having the trailer inertia pushing the truck in trying to pass the tow vehicle is extremely dangerous and deadly as it over comes the truck's braking ability.
Things in motion tend to say in motion. I think I read that somewhere from a guy named Newton! Claims it's the first LAW of motion. The external force counteracting the motion in the RV world is the friction between the road's surface and the vehicle's tires. More weight per square inch of tire foot print creates more friction on the same road surface. Hey, the OP's trailer's tires have more weight on them per square inch of contact on the road's surface than do the truck's tires right? Extremely hard to argue with that simple fact.
