frenchmr
Mar 01, 2019Explorer
laknox wrote:
Someone recently posted a link to a 60(?) gal bladder on Amazon along with a 12v transfer pump. Put that in the bed of your soon-to-be 1t, and you're good to go. :B I'm sure you could even find bigger ones, if you look, but then you're getting into weights. Frankly, with the lighter weight rigs you're looking at now, a SRW 1t would be fine as far as payload goes. Also, if you're going to have a "chase car" one, or more, of your kids might want to ride with Auntie instead of the truck. :B She could also carry some of the "stuff" that might be in the truck.
As for power, at minimum, get a couple 6v golf cart batteries and a good 100-200w solar panel and charge controller. If you've got some bucks to burn, look at building a Li battery pack from Nissan Leaf battery modules. NOT cheap, but you can get double the amp hours in half the weight and space of 2 6v batteries. Life expectancy is longer, too, and no maintenance.
That's great to see! I'm sure even getting a 30 gal bladder would probably do the trick, thanks. We definitely will want to get us much batter power as we can fit, and solar for dry camping.
About Fifth Wheel Group
