laknox
Aug 10, 2015Nomad
krazymatt wrote:
So I talked to Lippert. They said it could be the motor or gearbox neither of which is cheap.. So is there any way to pinpoint the issue?
Unless the motor shaft sheared off, if it's turning, it's working. Shear pins and gear box are the places to start if the motor's working. As you'll need to get the gearbox off to check it, you can see what the end of the motor shaft looks like.
Lyle
About Fifth Wheel Group
