Gearitis
Aug 10, 2015Explorer
I had a 2003 Cougar and last summer, I had a very similar problem. It was the gears as they are both Nylon. You can find the gears and replace, or the complete motor. I bought the gears and then bought the motor assembley with gears. I put on the new motor and repaied the older motor with new gears. The total cost was about 250 bucks but after replacement it worked like a charm. It is not hard at all. I have to bring my big slide in, and did it with my fingers once I had the motor off. Assuming yours is the same as my former 2003 the part was as follows: 18:1 Venture Actuator Motor for Slide Out 014-132682....here is one link that might help: Clicky I hope this helps...
About Fifth Wheel Group
