tarig's avatar
tarig
2003 5th wheel seahawk
purchased from private seller, been in storage about 1year getting ready to travel. Rig is plugged in to power, batteries charged, still NO power to rig. Cant find beaker box.
Model# FW33FKS 3 slides, 2003
  • Battery disconnect should not affect the shore power? I read it is plugged into power. Check the breaker for the shore cord, make sure it is on or not tripped. Double check the shore cord is attached to trailer tight (if marine style) or plugged all the way into the outlet?
    Also, check the converter box and see if the main 30 (or 50) breaker is off?
  • Do you have a battery switch similar to this near the entry door inside the trailer? 2005 Cardinal had one near to door and it was easy to knock it off with your foot. Chris
  • Does the rig perhaps have a 'storage' switch? Near the main door? Or in the electric bay?
