colliehauler
Feb 02, 2020Explorer III
Welcome to the forum. If it's set outside all its life I would check the roof over probably close to end of life. Check the tire date code and for cracking also look for uneven tire ware it could indicate a bent axle. Have wheel bearings been packed? Do the brakes need replaced? The biggie any signs of water intrusion? Do all the appliances work including A/C and heater?
If it was stored inside when not in use it could save you a lot of money in maintenance roof and plastic trim. If it's sat outside the graphics are probably a good indicator. Some people keep their RV pristine while others are extremely hard on them. If the latter maintenance probably has not been done.
Good luck with you purchase and let us know how it goes.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
