cephoto's avatar
cephoto
2004 Keystone Laredo, 29GR, plumbing/waste tank diagrams
I need to do some maintenance on my Laredo black/gray tanks, the associated valves and pull cables. Lube cables to waste valves if possible, replace them and valves if necessary. They're getting hard to pull. The problem is I'd like to know what I'm getting into before I open up the under carriage covering. I called Keystone and they insisted "no drawings, no diagrams exist. Call a dealer"
NOTE: the company that manufactures Keystone Laredo RVs apparently do it from spare parts and ad lib on the factory floor and use no diagrams/drawings... or so the customer service reps INSISTED. NO DRAWINGS.
I've also searched Google... not getting anywhere.
Does anyone else know where I might get an idea of what's up under the covering before I start removing it(it's one piece, covers the entire length of the RV frt to back). I'd like to see where the tanks are placed(2 gray/1 black) and how the plumbing going from them is laid out, where the valves are placed, how the cables run.
  • Being as this is not a tow vehicle.....but I believe a 5w......will move to the 5w forum.
    Marty
    TV moderator
  • thanks for the replies anyway. Sounds like more deconstruction than I'd hoped for but I want to get this done before one of the cables break and I've got more problems to deal with.
  • All you have to do is look at an RV long enough to realize there couldn't possibly be any plan they are built from based on the stupid stuff done to some.
  • Community Alumni's avatar
    Community Alumni
    Other that removing the under covering around the waste outlets and working back from there, I suspect there is not much else you can do.
  • not just your brand... same with Coachmen... can not find anything for my 2005.
    plumbing/wiring/etc.
    I just found the water pump... doing the winterizing...
    under the floor of the clothes closet... but above the real floor.
