Cheddarhead's avatar
Cheddarhead
2005 Jayco 5th wheel battery connection
My alzheimers is kicking my butt lately. I stored the camper last fall and pulled the battery out. Today I went out and had a brain fart as to what cable goes to which post. One cable is white and has a loop end with a red collar around the crimped end of the connecter. The other cables are a pair of black colored cables spliced into a green colored fused piece that connects to the battery. Common sense says that green would be ground and normally black cable is ground on a 12 volt system. I also assumed the cable with the red end would be positive. Well that's the way I hooked it and as soon as I touched the cable to the terminal I got sparks and blew the fuse. Anybody with a similar 2005 Jayco 5er with the same set up? Thanks in advance for helping out a brain dead weekend warrior...
  • bucky wrote:
    White is neg on both my Jayco and my Coachmen. I try to take pics on my phone when I know I won't revisit something anytime soon after I take it apart. My memory isn't what it used to be.
    I tried taking pictures but I don't know how to get the film out of the phone. :B
  • I took duct tape and marked my cables positive and negative... I too have terminal CRS..
  • White is neg on both my Jayco and my Coachmen. I try to take pics on my phone when I know I won't revisit something anytime soon after I take it apart. My memory isn't what it used to be.
  • kaydeejay wrote:
    The other end of ONE of those cables will be bolted to the frame. That one is your negative.
    Thanks, I just didn't feel like crawling all over trying to trace the cable since it goes into the wall inside the battery box and the the underbelly is sealed. I thought someone here would know and save me the trouble. I will probably use my multi-meter in the morning and check for the ground that way.
  • The other end of ONE of those cables will be bolted to the frame. That one is your negative.
