Lovesdunes wrote:
carringb wrote:
Great! But why did they trip? Are you plugged in at a park? If it tripped, the park power is probably dropping too low, and this alone will damage your windings in the A/C.
The circuit breaker tripped from user error at the thermostat. My fault. I was setting the temperature and moved the temperature slider up and down too many times trying to get just the right temp. The A/C turning off and on too many times tripped the breaker.
Will happen every time. Compressor gets its cooling from the refrigerant flow. If it is not allowed to run long enough between starts it overheats, sometimes breaker trips, other times the compressor's internal overload trips and will only reset after it cools
we had that same t'stat in our Rage'n, did not like it for that reason. They sell a conversion kit that includes a digital thermostat, way mo betta.
