focstay's avatar
focstay
2007 5th wheel Chapparral 267RLS discharge confusion
Hello,
My newly purchased unit has a 1-1/2 discharge line which I suspect is the grey water.
The large dia. 4 inch or so, which disappears forward a few feet and is across from the toilet. This is likely the black water.
They join to one discharge.
On my last unit I emptied the grey water tank through the black tank.
I'm not sure how to do this as there is a pull valve on each line. It appears to empty each tank separately.
Can anyone clue me in?
  • If you look at the handles one will be black and the
    other gray. The small line/pipe is the gray water and
    the larger is the black water. As the OP stated empty
    black 1st and gray 2nd
  • Hook up sewer hose to that 'common' 3" line
    Open black tank 3" drain valve
    When black tank is empty-----------use flush connection on side of rig to flush black tank.
    Close drain valve
    Open grey tank 1 1/2" drain valve
    Drain grey tank
    Close drain valve
    Add some water back into black tank......2 full toilet bowls flush is good. Keeps bottom of tank wet
  • Empty the black first and then open the valve to the grey to rinse the hose out.
