Bought a 2007 HitchHiker 32.5 UKTG....ordered it in Sept 2006
Went FT in 2007 for 7 yrs towing that 34' FW all over the USA weekly.
2 Adults/1 large dog. Roughly 80,000 tow miles
*Had to replace Demco Glide Ride assembly 1st year---warranty---recalled item
*Had to have roadside wall reattached to horizontal frame member 2nd year
(Crack formed at panel vertical seam forward of bedroom slideout....sidewall frame weld broken/sidewall bolted to horizontal frame at factory---warranty)
*Had to replace OEM leaf springs 4th year due to flattening ---replaced with 4000# spring packs
(7K axles with 3200 rated springs OR 3500 rated springs----depended on WHO was rating them.-----Regardless...springs were NOT overloaded as we weighed FW every year----scaled weight 13,873# Total----3090# Pin weight so 10,783# on axles)
*Had to replace one gear drive on large slideout 5th year....tooth broke
*Had to replace ALL furnace floor registers cause I broke them when I stepped on them....cheap louvered punch thin metal. Replaced with thick laser cut ones
Still have it.......
Need to replace bedroom Fantastic Vent fan lid controller....gears stripped
Would I buy another NUWA Product.???
YES_______YES______YES
