GPG52! wrote:
This is a long shot (likely not the issue here but...)
A few months ago we found that all of our 120v circuits in the kitchen were not working. (2014 Cougar 327 RES)
We finally figured out that the Ground Fault Circuit Interrupter (GFCI) in the bathroom had tripped and cut off all electrical power to the kitchen circuits.
Simple reset fixed the problem.
Sometimes the simplest and most obvious are overlooked.
Good luck on your hunt.
GPG :h
I have to laugh cuz we had a similar thing happen at our stick house. Front outside outlet would work one minute then upon plugging in the timer for Christmas lights,, poof nothing. Couldn't figure out what the heck was going on. Called local electric place and said to check for other outlets inside the house that are GFI to see if they tripped as the outside outlet wasn't GFI. Sure enough, our main bathroom's GFI was tripped. re-set and WHOLLA---outside outlet back to life. Ends up that the timer was to blame as it's the type that needs to "charged by turning it's clock a few times before plugging in". This year, bought a new timer.
