Old-Biscuit
Apr 26, 2016Explorer III
Njmurvin wrote:
All I can see from the archive info is "Panel Core Vacu-Bonded Sidewall". Are aluminum studs part of this construction? What am I missing?
Can't find it any more......use to be an cross-section exploded view of structure of 5th wheel showing roof trusses, sidewalls, flooring, insulation etc etc.
I have a 2007 II LS (LITE SERIES)
We FTd in it for 7yrs
It has aluminum framed sidewalls that are filled with the Dow Blue Insulation and interior/exterior walls are glued to studs under vacuum.
Roof is 2X4 wood trusses overlaid with plywood
Subfloor (1" OSB) is laid down on top of 5vr frame
Need more details.....contact NUWA
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
