Blackdiamond
Feb 05, 2019Explorer
Dennis58 wrote:So 90 lbs on a truck....probably is 500+lbs on a TH
Data Point;
LINE-X will add like 500 lbs" - False, We spray exteriors around 65mils on average. At that thickness you achieve the tough coating you want and don't add a significant amount of weight. Less than 90 lbs on average for a full size vehicle completely sprayed. About as much weight as your cooler stocked with "sodas" and ice.
About Fifth Wheel Group
