tomthyme's avatar
tomthyme
200psi air compressor
Hello Folks!
We just upgraded from G to H rated 17.5" wheels and tires on our Carriage Cameo. My home air compressor is rated at 125psi max, so I doubt I will be able to get to the recommended (Max) cold PSI in the tires of 125 for my regular tire checks. We're considering a new compressor that has a 200psi max rating. I've found a few options from Lowe's and HD at around $325-$350. Does anyone have a favorite here?
I have also considered getting one mounted to my new f350, but I haven't found one that carries the capacity I need and can leave the bed free for other stuff we carry.
What do you folks do?
Thanks
Tom
  • rhagfo's avatar
    rhagfo
    Explorer III
    Cummins12V98 wrote:
    Me Again wrote:
    If you look at the inflation chart the tires rated to 4805 each do not require the full 125 pounds. I doubt that you have 19220 pounds of the two axles.
    Here it is:
    80 3375
    85 3540
    90 3695
    95 3860
    100 4010
    105 4180
    110 4330
    115 4495
    120 4650
    125 4805(H)
    I ran 107# on my MS with the GY "H" 17.5's and had more capacity than they needed at that pressure. They wore great and ran cool. I would bet these tires had 30K or so.
    According to RV guide, 15,999# GVWR, less 20% pin = 12,800# on the axles 12,800/4 = 3,200# ea. tire, so you really only need to inflate to 80 psi. If you went to 100psi, they would carry the entire weight of the 5er+ 16,040#.
  • I agree with C Bears and the reason for that is the heavy bead construction and the high air pressure. Don't get over confident because the seals on screw in valves just get tired and can start leaking. So I don't think he is suggesting you don't need to check. He knows what he is saying because he checks and we all should keep checking.
  • If you want a compressor look into the ViAir compressors. Many of them are 150psi rated.
    Like others have said be sure to run the proper pressure and not the max pressure., which your 125 psi comprssor will easily handle.
  • When coming off the Pismo Beach sand dunes I need to inflate the tires from 30# to 70#. California Air Tools has a robust compressor that easily operates on a 1k watt inverter, no genny necessary.
    Here it is:
    80 3375
    85 3540
    90 3695
    95 3860
    100 4010
    105 4180
    110 4330
    115 4495
    120 4650
    125 4805(H)
  • Ivylog's avatar
    Ivylog
    Explorer III
    Me again is trying to tell you to go weigh your rig and adjust your tire pressures based upon the weight of the tires are caring. More than likely you do not need 125 psi for the weight, even going five PSI over for a safety factor.
  • Something else to consider before laying out huge bucks for a high end compressor. My current G614's have not required an air adjustment for 2 years of full timing.
    We have been in different temperature extremes, put a lot of miles on, and sat in a couple different spots for 3 months at a time.
    My previous set of G614's were the same, they just never needed air adjustments. Good quality heavy rated tires don't lose air in my experience.
  • If you look at the inflation chart the tires rated to 4805 each do not require the full 125 pounds. I doubt that you have 19220 pounds of the two axles.
    Here it is:
    80 3375
    85 3540
    90 3695
    95 3860
    100 4010
    105 4180
    110 4330
    115 4495
    120 4650
    125 4805(H)
