Iqoair's avatar
Iqoair
2011 Cedar Creek equalizer question
We just picked up a 2011 Cedar Creek Silverback 5th wheel, so far so good. I am concerned about one of the equalizers on the suspension. Looks like the rubber cushion is pretty squished or worn. The other side isn't as bad. I'm thinking it may be a good idea to replace them? Tire wear seems good, and the same on all tires. Thoughts?
Thanks in advance.
http://www.flickr.com/photos/iqoair/10180758183/in/photostream
Hopefully image worked.
  • Tell me more about the HD non rubber replacements. Where did you get them?
  • Dexter will replace them free of charge. Yours are shot. Send them that pic. I opted for a pair of H\D non rubber equalizers due to not wanting to replace them again in 24 mos.
  • Same problem. Dexter replaced them and have not seen a problem since. CHINA rubber according to Dexter. Best results were dealing with Dexter directly.
  • Those are the Dexter ez flex. I put those on two years ago and they had a problem with the rubber for a while. I got them replaced and the second set did the same thing in about six months. I finally got tired of taking my suspension apart and tossed them and got the trailair egua-flex and my troubles went away. Trailer even seemed to ride better.
  • That looks like an E-Z Flex by Dexter......think they have a 2 yr. warranty.
    Get in touch with Dexter....LINK
    X2 on the 'wet bolt kit'.......better bushings for spring eyes and greaseable bolts
  • You probably have the trailair equalflex system. I am not sure it is still available. Installed mine about 5 years ago and I also have one rubber squishing out. Not too worried about it. I keep a watch on it and it has not changed. You could change it for another brand. While your at it, install a wet bolt kit. You wont regret that decision.
