tinner12002
Sep 05, 2016Explorer
jam5158 wrote:
I have 2013 Eclipse Attitude 23FB. While on a cross country trip I smelled rubber burning and when I checked I saw the trailer tires were rubbing the wheel well of the trailer. After some investigation I found several cracks in the I-beam frame where they had welded support plates parallel to the beam above the springs. The trailer body had started swaying because of the cracks that were all the way through the beam so that the wheel well was rubbing the tires. Unfortunately I am 2300 miles from home in Tennessee. I stopped at a camping world and they would not touch it. Currently I have several calls into local truck trailer repair shops in the area but because it is a 3 day weekend I am stuck till someone calls me back. From reading this forum it is obvious that the construction welding done by Eclipse is sub-standard because things like frame failure should not happen on a 3 year old trailer. {snip} I was looking into a new trailer but with this kind of damage I will get next to nothing on a trade in.
Mod Edit, as per the forum rules, "Posts are not allowed in which a local, state, or federal consumer action board and/or legal counsel is/have been involved. This includes posts related to future, ongoing or past lawsuits."
The scary part of that pic is, that is the way lippert braces all its spring perches on all their toy hauler frames! I had asked one manufacturer I was talking to if I purchased one of their haulers would they have lippert use a vertical gusset stitched in between the flanges top to bottom on the inside and outside of the frame rails like a structural brace is suppose to be installed when something is welded to the flange of an I-beam. They said they could request that.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
