Garyl53
Aug 18, 2015Explorer
I have the Sidewinder and have an F250 CC with the 6' 8" bed like yours. I think you will need to carefully calculate if you still need the Sidewinder so you clear the cab before you go for a new pin box solution. I elected to raise the trailer using the Lippert Correct Track II Kit since it is a fairly low cost option and I could do it myself. It provides about 2" lift plus provides capability to align the trailer. Other option is to change axles to be under the springs if not already configured that way.
About Fifth Wheel Group
