SkiSmuggs
Aug 29, 2015Explorer
Poppy's 5th Wheel wrote:
Hey there SkiSmuggs! Long time no talk to. Maybe I can help by looking at it from the other direction. I replaced the OEM PIN on my 299RKS with the Mor-ryde and here's a picture of the label.
Poppy, this is a great help, but I see from the gvwr that your spring rate was way too high for our units and would have been too stiff. We should use the 11500 lb pin box which is the 03 instead of the 05 that you had. I know you've moved on, but this is for anyone else considering the Moryde. The model should be selected for the actual loaded weight of the fiver.
About Fifth Wheel Group
