AVCM Retired wrote:
My wife and I bought a 2013 Artic Fox in November 2012. Since then we have had to take it in 3 times, and are about to take it in for the 4th time, to get the electronic dump station fixed. The first two times the adjusted and lubed the valves and that worked for a time or 2. The last time they replaced the black water valve and adjusted the other two.
When I went to dump last weekend, the black water and gray water #1 would not dump... I cant even begin to tell you how frustrated we are.
The dealer tells me we are the only ones having this problem. So this is my question, is anyone else having this problem, and if so were you able to fix it? Thanks
yep same unit with the same problem here
