MFL
Apr 13, 2017Nomad II
I'm thinking the newer DRW trucks actually sit lower than the 3500 SRW, so even though you may be towing a little nose high, it should work. You can measure the FW over hang, to ground, and then ground to bed rail of truck. The truck will squat a little when hooked up, but not a lot, with that size trailer.
I have a Dometic 9100 electric awning that works well for me. The wind is not your friend with most electric awnings, so can limit use.
Jerry
Jerry
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
