SpencerRB
Aug 01, 2013Explorer
Sinecure wrote:
So far so good with mine (knock on wood). My only complaint is the poor A/C ducting. It seems a lot of the cold air is dumped into the attic, and very little makes it out of the vents. Make sure the one you buy has good air flow out of the vents, and if not be certain to make the dealer fix it before purchasing, or get it in writing that they will fix it after taking delivery.
They all have poor air flow due to the way they punch holes in the ceiling to add the vents. Easiest solution is to pop the vents off and fully seal the edge of the openings with foil tape. Also a good idea to check the ducting with a mirror to verify they are all fit together properly.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 03, 2021
