mowdoc
Oct 06, 2014Explorer
The handle by the black tank valve is the gray water from the bath sink and shower. The frame mounted handle near the sewer connect under the side is the gray tank that catches the kitchen sink water.
When you are going to dump the tanks, dump the black tank first. Don't rush and give it time to drain. Connect a hose to the black tank flush fitting and let it run full stream for a few minutes to clean the bottom of the tank and flush plumbing involved.
Once that tank is empty close it and open both gray tank valves. Also give these time to drain.
If you use the "blue stuff" in your black tank it will not cause foul oder. I like to add a small amount of laundry detergent and a cup of bleach to both my gray tanks before use. Just put the soap and bleach down the sink drains with running water to wash it all the way to the tank. When you drain those gray tanks the water will be clear and oder free. It cleans the sewer hose for you too.
About Fifth Wheel Group
