Cummins12V98
Jul 09, 2016Explorer III
NC Hauler wrote:
I'm in the middle hole as far as height and I'm 2" in front of the rear axle...Just wondering, with the rear air suspension, do you think I'll be ok with this set up..I can go higher or lower or move pin over the axle..Any thought's on this? I figured with 17.5" wheels the MS might set a little higher.
Does your new MS have the 2" riser? I would say the mid hole full forward should work with the MORryde pin box.
FYI the cost to add the 2" riser is about $1,800. Let's hope your dealer ordered that 3-$400 option!
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
